Good day to you all. Does anyone knows how to drain the condensate from lift airconditioning unit??? Since you can't have a fixed connection (lift is moving) is the condensate just free fall down to lift pit floor?? Is it safe doing this? If its ok, will proposed to add small sump pump remove the condensate from the pit..
