Previous in Forum: wind turbines   Next in Forum: SYNCH MACHINE
Speed Loop and Current Loop Basics
11/12/2008 1:40 AM
Dear All
I want basic working of Speed loop and current loop in case of AC DC Drives.
Regards
Technology
Re: Speed loop and current loop basics
11/12/2008 6:57 AM
What do you do?
design or repair? or only aware of it?
simple words, they will construct a close loop system which can made motor run stably. current loop has less time constant than speed loop has. so that they will have more sensitive at current control.
this system can be implemented by an inverter, if you hope to buy availble on the market, current and speed feedvack signal acquired from sensors to its inputs. of cause if there is no such sensor, inverter can work well as well, but its belong to open control, you can imagine, it has no better features and no as well pricise as this two loop control.
Good Answers: 15
Re: Speed Loop and Current Loop Basics
11/13/2008 12:18 AM
speed and current will have different uses
for a steady speed, you'll have a variable current (usually torque drives)
for a steady current you can have variable speed...
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Register to Reply 2 comments
