Hello, I am designing a stationary gantry crane and I need a bit of advice concerning the size of I beam to use. My plan is to use 8x8 posts set in concrete (4' depth into the ground, 8' height above the ground). I will also use 8x8 bracing set at 35* angles on the for and aft sides, also set 4' deep in concrete, and connected to the uprights at 32". The span will be 16', and the load I will be lifting will be 1,000 lb. maximum. I will be using this "crane" to help in the removal of engines/transmissions. I have looked into several mobile gantry cranes but I really don't need it to be mobile if I can build it the way I envision it, plus I would have to modify a store purchased unit to handle the rough terrain it needs to be used on (no, it's not under a shade tree in the grass-LOL).
I have searched the web trying to find load calculations in layman's terms, and called a few steel suppliers, but I have come up empty so far. While searching this morning I stumbled upon this site and figured it wouldn't hurt to ask. Can someone help me out?
