Previous in Forum: PLC5 Watchdog Timer Issue   Next in Forum: battery charger
15 comments
Battery Charger for Battery Bank
11/12/2008 11:15 PM
please help me to find out a suitable charger for a battery bank of (8*( 12 volt 150 ah))
Good Answers: 42
Re: battery charger
11/13/2008 3:52 AM
Please go to the nearest electrical market dealing with electrical machinery and tell them to supply you one. In India battery dealers have dealership of battery charger also.
Good Answers: 123
Re: Battery Charger for Battery Bank
11/13/2008 9:38 PM
When fleets need to charge, or maintain multiple batteries, usually a charging rack is made. What I have seen has been a pair of copper bars about 3/4" tall, and 1/4" thick, mounted to a wood plank, on a wall. The batteries are set on a wooden or metal bench below the wood plank. The battery charger was connected to the copper bars by heavy cables, appropriate for the output of the charger. Red and black jumper wires with alligator clamps on both ends were used to connect the batteries to the copper bars always connected positive to positive, negative to negative. As long as all batteries are the same voltage as the charger, this works well. When 6 volt batteries needed charging, two were hooked up in series to achieve 12 volts, then that battery pack was connected to the charging bars.
The charging rate of your charger will depend on how much current is being used from your batteries, and how fast you must recharge them. A 1 amp solar charger could be used if you only need to maintain them in a charged state while storing them. If current is being used, you will need higher charging rates.
Two caution notes to be aware of.
If you are using only one charger to charge all 6 batteries, they will be effectively connected together in a parallel circuit. All batteries will share all of the loads. If one battery develops a dead cell, it will drain all of the batteries. You will need to regularly check for this. If you use diodes to isolate the batteries, the voltage will be .7 volts lower in the batteries than the charger output.
Charging batteries produces dangerous gasses. The gasses are explosive, poisonous, ans very corrosive. You MUST charge the batteries in a well ventilated area, preferably out of doors. Look where these gasses can collect. Sulfuric acid is very dangerous. Please be careful.
Bob
Good Answers: 32
11/13/2008 10:39 PM
Is this for an Electric Vehicle?
johny451
Good Answers: 247
11/13/2008 11:44 PM
Zivan has a good reputation. I assume your batteries are in series, so you'd need a 96 volt model.
Good Answers: 123
11/13/2008 11:53 PM
For no particular reason, I had assumed they were separate. Now I wonder
Can you help me find a rich woman with a bad reputation?
Bob
Good Answers: 15
11/14/2008 3:10 AM
Hi Assuming these are At a professional level, that is to say you are going to be charging these regularly, you need to get a charger that is fully automatic if you want a good life for your batteries. If you are deep cycling them, i.e. using >30% of the declared Ah then a three stage charger is best. Go see www.mastervolt.com and www.victronenergy.com. You may get cheaper chargers there in India(?) but they should have the same charge characteristic.
If they are in standby mode, like a UPS, then a cheaper permanent float unit will be ok. this should still be automatic but be careful, many cheap chargers say they are automatic when in reality they are nothing more than a transformer and a rectifier. these will overcharge your batteries and ruin them....I earn a lot of money from boats who try to save money on a cheap charger! In both cases it is wise to have a unit that has temperature compensated charge levels. A 24V battery has 0.6V difference in the charge levels between 25ºC and 35ºC. It doesn't seem like much but I assure you it makes a big difference.
we can help more if we know more about the voltage and application of your accumulators.
regards
Chas
Good Answers: 42
11/14/2008 8:52 AM
Hi Capblanc,
" You may get cheaper chargers in India?"
In India there are hundreds of battery charger manufacturers ( Some are highly reputed manufacturers having products with latest technology and competent engineers) provide high quality chargers depending on the customer's requirement . The cost depends on the quality and type of requirement. The battery chargers used by automobile battery charging shops need not be such sophisticated design compared to to a battery charger required for a UPS of telephone exchange or a UPS of computer installation or aircraft battery charging bay or space technology center and any other sophisticated requirement.
Good Answers: 15
11/14/2008 10:11 AM
Hi V.I.
Exactly, I would suppose that national brands will be a lot cheaper than imported brands. The point I was making is that it will need to be of an appropriate type as many simple chargers are called "automatic" when in fact there is no regulation whatsoever and, if left on the battery unattended, will allow the voltage to rise and result in uncontrolled gassing with very rapid demise of the batteries.
I am of course assuming that the OP's application is 8 batteries in a bank rather than 8 individual truck batteries. You know as well as I that the OPs rarely give enough info to give an answer without making some assumptions.
regards
Chas
Good Answers: 42
11/15/2008 12:33 PM
Hi capblanc,
The actual problem is guests or members expect us to assume and answer the threads giving half information or no information . So we get little agitated and answer half heartedly. Battery charging and battery maintenance is such a vast subject that we may need half an hour to give full explanation where as they want shortcut answer and hey will not come back to the thread even to give a feed back. So we actually get irritated as we spend lot of our valuable time to reply to some one who do not even care to read what we write in reply.
Good Answers: 123
11/15/2008 1:12 PM
You deserve a GA for that reply.
Bob
11/14/2008 8:09 AM
Dear Friend
We manufacture battery chargers. Pls. inform application & send offline enquiry to uni_insta@dataone. in or ashoktoshniwal@yahoo.com
Thanks
Ashok Toshniwal, Bangalore, India
Good Answers: 39
11/14/2008 4:18 PM
Mayaranjith are you the " guest" who requested information on battery chargers for marine propulsion in the next forum thread. In that request th e battery bank is 24V at 600 A-H which is same as 8 X 12V @ 150 Amp hour.
You should be aware that propulsion use is deep cycle and this is a somewhat different application that what a lot of so called marine chargers are intended for.
My recommendation would be for Victron brand. the product is manufactured in India even though th ecorporate HQ is in Holland. I have been using these for marine applications of deep cycle bank in the 600 - 1200 amp hour suizes for five years now. These can be used on either 50 or 60hz mains at either 120V or 230V If you are using AGM type batteries you can use multiple chargers in parallel for faster recovery. These units are rugged enough to stand up to Coast Guard patrol boat use. I have 124 systems in use right now and so far zero failures. They were installed in 2004 - 2005.
Elnav
Good Answers: 15
11/15/2008 4:42 AM
Hi Elnav
Nice plug for Mr Vader's product, but we shouldn't be pushing our agencies so overtly. I personally prefer Mastervolt, and I can come up with even larger numbers, but that is not the point.
regards
Chas (Electromarine Balear)
Good Answers: 39
11/16/2008 6:24 AM
Well I can only speak to those products that I have good experience with. It would be a poor thing to recommend products with which I have had bad experience with, would it not? I have used both products and have some relevant information regarding how both brand names are manufactured and designed. I based my recommendations on my own personal experience. Since the original poster apparently is near India , I suggested a brand I know is made in that locality.
Elnav
Good Answers: 15
11/16/2008 11:42 AM
Hi Elnav,
Valid point, forgive my critisism. BTW current mastervolt units are made in China.
Most 24V systems in europe now spec Mastervolt or Victron. My guess is 70%/ 20%. and 10% to other brands.
We work on a certain amount of remote house systems where Trace (Xantrex) is the dominator in the market.
Register to Reply 15 comments
Anonymous Poster (1); Blink (1); bob c (3); capblanc (4); elnav (2); Johny451 (1); V.I.Abraham (3)
You might be interested in: Battery Holders
