Previous in Forum: over-unity devices   Next in Forum: Pneumatic Cylinder competition
17 comments
India - Member - Engineering Design Services ( embedded electronics)
Accurate Fuel Flow Measurement for Mileage Calculation
11/13/2008 2:16 AM
Hello ,
This is George from Ananya Innovations.
We are trying to build in a feature for the vehicle tracking hardware unit to accurately measure the flow of fuel to engine to calculate consumption and mileage, however not able to source the sensor/meter for it.
Could anyone help with an idea in this regard.
Thanks in advance.
Thanking you,
Best Regards
George Kottackakathu
APPLICATION is the essence of LEARNING - develop a PASSION for it
Re: Accurate fuel flow measurement for Mileage calculation
11/13/2008 6:39 AM
Flowmeters are normally expensive and require some good electronics to work fine.
Have you considered using some EFI frequency signal and fuel manifold pressure to calculate the fuel flow?
If flow measurement is really necessary, cox instruments are the guys who supply most of the fuel flow measurement devices.
Humm... suspicious you are...
11/13/2008 10:35 PM
Hello Bhrescobar,
Thank you for the reply.
Would check with cox instruments for our requirement
Thanking you,
Best Regards
(email : George@Ananyainnov.com)
Sr.Engg- Marketing
ANANYA INNOVATIONS LTD,
702/7, Avinashi Road,
Coimbatore - 641037,
Tamilnadu, India
T : +914224332080
D : +914224332471
Fx :+914224332200
C : +919944904304
Skype : george.ananya
www.ananyainnov.com
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
Re: Accurate Fuel Flow Measurement for Mileage Calculation
11/13/2008 11:02 PM
gentle man the fuel consumption is measured in grams/BHP/Hour and published as per relevent ISOs ltr/KM or mile is a unit employed by clever marketing lot.
crm
Run silent run deep
11/14/2008 1:52 AM
crm,
Of course litres/100Km and MPG are averages but it seems to me the car manufacturers would all use the same misleading testing and calculation methods to be competitive with each other.
Also it seems to me that the g/BHP/Hr would vary with RPM (I could be wrong) so that measure would also be subject to varying test conditions, wouldn't it?
Gordie
Logic is the art of going wrong with confidence. -- Morris Kline
11/16/2008 5:02 AM
You are 100% Right, The test conditions are as per ISO Standards in force.as far fooling the ignorant customer is concerned the fuel consumption by vehicle manufacturers publish in Km/Lt or Miles/Litre's at Ideal Conditions or Test conditions at Factory tracks .even god doesn't know what does the statement mean. Then you have manufacturers of gadgets to enhance fuel consumptions legally picking the pockets of educated end users!
11/16/2008 9:05 PM
Well here in Canada we use Litres per 100 Kilometres. With the disclaimer "Fuel consumption ratings based on Transport Canada approved test methods."
I don't know if it's because the 'powers that be' wanted to quote fuel consumption rate instead of 'kilometrage' or just to make it hard to convert with simple conversion software to/from mpg. (Do you hear that Josh Madison?)
I think perhaps you meant "legally picking the pockets of UNeducated end users" or perhaps "poorly educated" or "brainwashed".
Gordie
11/14/2008 2:07 AM
I read somewhere that for really accurate real-time flow rate measurements that sound pulses were passed through the fluid in both directions and the difference in the time delays or Doppler shifts were used to calculate the flow rate.
For a cheaper solution you could use mass flow measurement. (wind chill) You pass a fairly substantial current through an RTD and measure the temperature to see how fast the fluid is taking the heat away. All you need to know is the thermal conductivity, thermal capacity (specific heat?) and temperature of the fluid. These should be known, known and measurable for your fuel.
And one final word: Injection. (If the engine is injected you should know how much fuel is injected per cycle. Just count them.)
Gordie.
11/14/2008 9:32 AM
Hi on my boat i use a device which tracks my fuel consumption made by Flowscan. Hope this helps.
11/14/2008 10:16 AM
Try Flow Scan (or is it Floscan?)
They make fuel metering equipment.
Travis
11/14/2008 12:52 PM
on a fuel injected car you will need to meters. One on the fuel to the rail and one on the return fuel, then subtract to get use. Here is one. Look up fuel meters used on small planes or jets.
http://www.directindustry.com/prod/hoffer-flow-controls/micro-turbine-flow-meter-for-liquids-9075-58353.html
11/14/2008 9:30 PM
See http://www.scangauge.com/ I have bought a scangauge to test fuel milage increasing devices. It's showing a decrease so far, but I am still testing. I question the scangauges accuracy, as I did a test the old fasoned way and had opposite results. Unforunantly I have to do hours of more driving to figure out whats going on. If you discover any malfuntions with the scangauge, please let me know.
11/16/2008 1:20 AM
I guess the question here is how is the car measuring the fuel rate? Because as far as I can tell from their web page the ScanGuage is just reading ODB info from the car.
If the car has an accurate flow meter then ananyinnov can just go down to his local auto parts store and pick one up.
Gordie
11/18/2008 6:24 PM
The way that ScanGuage works is by using Distance value from the ODB-II serial data stream and then dividing by the Mass Air Flow value from the ODB-II serial data stream and assuming stoichiometric combustion (not really true but probably close enough) to get the petrol consumed with the appropriate scaling factors to get the desired units. They can do some averaging to smooth the signal out as well as integrating the values to give overall rates as well as the instantaneous values.
If you are a bit more adventuresome slinging electrons, here is a link for DIY monitor:
www.windmill.co.uk/obdii.pdf
Cheers !!
07/11/2009 9:13 AM
Hi, Bell Flow Systems do Fuel Consumption Flow Meters which are accurate. http://www.bellflowsystems.co.uk/fuel-oil-flow-meters/engine-fuel-consumption-flow-meter-range/
Cheers
07/30/2009 11:58 PM
Hi,
This is Md Fazle Rehman from OCL India Ltd., in technology division.
We are also trying to develope same, till yet i have concluded to have two flowmeters:-
1- 1st at fuel outlet pipe.
2- 2nd at fuel returnflow pipe.
then both the data recorded by the GPS system and will be calculated.
But the bottleneck which i am facing is to have the flowmeter of that size with accuracy measurement.
If you do get any idea or resource for it then please do contact me at mdfazlerahman@ocl.in
06/01/2010 3:50 AM
CR4 ADMIN: Deleted Post #16
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
08/28/2010 9:53 AM
Hi All, I am interested in finding the solutions to the said forum. Anyone with an accurate solutions to this? Please advice. Thanks & Regards, Darren
Register to Reply 17 comments
ananyainnov (1); Anonymous Poster (6); bhrescobar (1); Brave Sir Robin (1); buzneg (1); crm (1); dlyc5033 (1); GordieGii (4); vicini (1)
You might be interested in: Bug Tracking Software, Fuel Cells, Fuel Testers
