Previous in Forum: Half Coupling vs. Weldolet   Next in Forum: Anchor Load
Air Motor Design
11/13/2008 10:23 PM
Hi ,
I am a Year 2 student in Mechanical Engineering . I need information on design , build and test a piston-type air motor . Below is the information that are given to me :
1. A self-starting air-motor
2. Output power : 12 W
3. Rotational Speed : 600 rpm
4. Motor should fit within a size envelope of 110mm x 150mm
5. mounting : flanged mounted , per the attached drawing - number AM05001
6. air ( oil-misted ) is supplied at room temperature and at up to 4 bar by a 6mm pneumatic ine. A 1/8 Gas push-in pneumatic fitting should be used on the design to accept the pneumatic feed ( 3601_06_10 )
7. An overall efficiency of around 60% should be assumed in initial calculations.
My problem is , I do not know how to start the calculations and dimension sizing on the parts and formula needed to perform calculations . I need advice . And I hope you can give some information about all this , any files or info will be deeply appreciated . Thank you very much .
Looking forward for reply ,
Sincerely ,
Richard Chen
User-tagged by 1 user
Good Answers: 183
Re: Air Motor Design
11/14/2008 8:33 AM
1 start with the choice of cylinder number better an uneven one either 5 or 7 if you aim at a ripple free function if it is not compulsory you can build on 3 pistons basis.
2 let the dead volume be as small as possible since it reduces the volumetric efficiency
3 make the choice of the ratio stroke/ piston diameter and of the cinematic i.e. connection between pistons and shaft. Decide if you design a radial or axial motor type.
The rest is application of thermodynamics rules and formula you have in any book and computation of the mechanical strength of parts. If you have connecting rods do not forget stability check under compressive loads.
If you are with your work advanced I am willing to check it and give you further hints but I shall never make your work. For it use the PM channel
11/16/2008 9:28 AM
Why uneven number of pistons ? What is the advantages between 2 pistons basis and 3 piston basis ?
What is dead volume ?
I have initiated some initial calculation on power and energy . I could use more hints from you .
Regards
Good Answers: 183
11/16/2008 2:51 PM
I would suggest first you register on CR4.
Second you explain what you already did and then I can help you further. I will always correct what you have done but first you have to do your work: thinking, computing, a. s. o.
OK? Than proceed.
11/30/2009 7:35 AM
Hi.. i am doing the same project and i need to know what formulas to use for calculations. any advice will be apreciated. Thanx.
