Previous in Forum: V4148 Zener   Next in Forum: Star/Delta Convertor for 220V/380V Three-Phase Motor
Location: Somewhere near BF, Arizona. ...seriously! ...we're that close.
Motor Efficiency
11/14/2008 5:57 AM
Hey Folks,
A question of motor type vs. efficiency came up:
Which is more efficient overall and why? A DC stepper gear motor or an AC gearmotor with a VFD? The application is a celestial drive for a large inertial load. Assume that both DC stepper motor and AC gearmotor are of similar power and torque capability to drive the load. The output speed of each drive train must be equal.
It was hypothesized that the AC would be more efficient even with the the VFD's inefficiency in converting the input AC line voltage to DC and then back to the frequency controlled AC where the DC stepper might experience inrush scale current on every 1.8° step, and there would be additional parasitic control circuit losses that must be included in the DC scenario. Can someone shed light on this for me?
There are people who make things happen, there are people who watch things happen, and there are people who wonder what happened. To be successful, you need to be a person who makes things happen.. Jim Lovell, NASA Apollo 13 Hero
Pathfinder Tags: Variable Speed Motor Control
Good Answers: 53
Re: Motor Efficiency
11/14/2008 7:40 AM
Hi Don.
In my opinion, you need to plot a load line with a torque speed curve, and that can give you better answer, as there may be very much possibility that both are better than one another but at different speed.
Its difficult to set a thumb rule as design of motor is also equally important, what consideration had been taken during the design of motors?
very small AC induction motors have efficiency ranging in 10 to 15% at the same time you can have bigger sizes with 95% efficiency.
11/14/2008 8:10 PM
For the different Hp vs torque I took the path of a 1/4 Hp motor & 1/2 Hp VFD for overdrive speed. The three phase motor had a 72% efficiency, and I'm sure driving it down at such a low speed; "in the weeds," so to speak, will put the efficiency of the entire system fairly low, but inherently, how do steppers compare? The one my colleague wanted to use was a similar torque output 24 VDC gearmotor. My thought was: think of the I²R losses at such a low voltage!! So who's right?
Thanks,
Don
Good Answers: 56
11/14/2008 11:36 PM
When it came time to choose a twin axis drive environment for a large aperture fork mounted scope, I went with Pittman geared motors and integrated encoders managed by a Sidereal Technology microprocessor based electronics.
I did not want to deal with the periodic error common to worm drives so I chose instead to use a hardened steel ring gear and steel pinion; a simple steel on steel friction drive for the right ascension drive
I have more concern for effectiveness than efficiency. The power consumption difference between the Pittman motors and the equivalent steppers is not enough to be concerned about.
You did not say how heavy your system is but I can't imagine this response being significantly different even for a very heavy mount.
L.J.
"Both the revolutionary and the creative individual are perpetual juveniles. The revolutionary does not grow up because he cannot grow, while the creative individual cannot grow up because he keeps growing." Eric Hoffer
Register to Reply 3 comments
Laughing Jaguar (1); rakesh_semwal (1); Tucson Don (1)
