Previous in Forum: Signaling Pressure in Hydraulic Lines   Next in Forum: Ammonia manufacturing Plant P&ID diagram
INSTRUMENTATION
11/14/2008 8:43 AM
PLEASE LET ME KNOW WHAT IS DIFFERENCE BETWEEN DDC AND PLC.
AS ON DATE WHICH ONE WOULD BE PREFERABLE FOR BLAST FURNACE CONTROL DDC OR PLC.
Re: INSTRUMENTATION
11/16/2008 7:44 PM
Well...
DDC is a "direct digital controller" while the PLC is a "programmable logic controller"
Usually the DDC is designed for Building Automation and Control System, meaning for the Building System wherein the HVAC, Lighting Control, Electrical Power System and other Building system requires for the monitoring, trending and control based. This is being called Energy Monitoring and Control System or EMCS. They have a common protocol to DeviceNet configuration.
While the PLC is commonly used for industrial system, whereas requires more than you are expected for monitoring, trend and controlling. SCADA is goes with it for real-time simulation, monitoring and controlling of the process variables based on the field mounted instruments.
I think, you may consider the PLC for blast furnace control.
Eren
Re: INSTRUMENTATION
11/17/2008 1:35 PM
Thanks ,
I got some information from you.
I will writing to you in deatils very soon
KALYAN
Register to Reply 2 comments
