Following information taken from "Wikipedia" (the free encyclopedia)may be useful for starting the paper.I have not been able to get a circuit diagram.
WiMAX (Worldwide Interoperability for Microwave Access) is a technology to allow devices to form wireless connections to permit the carrying of internet packet data.
It is similar to WiFi in concept, but has a number of enhancements designed to improve performance and permit usage over much greater distances.
The term 'WIMAX' itself is a certification mark for products that pass conformity and interoperability tests for the IEEE 802.16 and ETSI HiperMAN standards.
WiMAX is a standards-based wireless technology that provides high-throughput broadband connections over long distances.
WiMAX can be used for a number of applications, including "last mile" broadband connections, hotspots and cellular backhaul, and high-speed enterprise connectivity for business. The public driven wireless internet wimax & wisp access roll out map is now available.
Additional information on the subject are quoted below:
Technical advantages over WiFi
Because IEEE 802.16 networks use the same LLC layer (standardized by IEEE 802.2) as other LANs and WANs, it can be both bridged and routed to them.
An important aspect of the IEEE 802.16 is that it defines a MAC layer that supports multiple physical layer (PHY) specifications. This is crucial to allow the standard effort to evolve and adapt to various types of end-use requirements. It also allows equipment makers to differentiate their offerings. This is also an important aspect of why WiMAX can be described as a "framework for the evolution of wireless broadband" (copyright WiMAXPro.com) rather than a static implementation of wireless technologies.
Enhancements to current and new technologies and potentially new basic technologies incorporated into the PHY (physical layer) can be used. A converging trend is the use of multi-mode and multi-radio system-on-a-chip (SoC) and system designs that are harmonized through the use of common MAC, system management, roaming, IMS and other levels of the system. WiMAX may be described as a bold attempt at forging many technologies to serve many needs across many spectrums.
The MAC is significantly different from that of IEEE 802.11Wi-Fi (and Ethernet). In Wi-Fi, the MAC uses contention access—all subscriber stations wishing to pass data through an access point are competing for the AP's attention on a random basis. This can cause distant nodes from the AP to be repeatedly interrupted by less sensitive, closer nodes, greatly reducing their throughput. And this makes services, such as VoIP or IPTV which depend on a determined level of quality of service (QoS) difficult to maintain for large numbers of users. By contrast, the 802.16 MAC is a scheduling MAC where the subscriber station only has to compete once (for initial entry into the network). After that it is allocated a time slot by the base station. The time slot can enlarge and constrict, but it remains assigned to the subscriber station meaning that other subscribers are not supposed to use it but take their turn. This scheduling algorithm is stable under overload and over-subscription (unlike 802.11). It is also much more bandwidth efficient. The scheduling algorithm also allows the base station to control Quality of Service by balancing the assignments among the needs of the subscriber stations.
Some more information on the topic are furnished below:
Uses for WiMAX
WiMAX is a framework for wireless development based on a forward-looking core set of technologies. More recently 3GPP cellular's 4G, 802.22 Cognitive Radio RAN (Rural Area Network), and 802.20, the High Speed Mobile Broadband Wireless Access (MBWA) Working Group, have shifted toward use of similar constructs of multi-channel scalable OFDM, HARQ, FEC, MIMO-AAS and other complementary technologies as are part of WiMAX. WiMAX is designated as the metropolitan area network (MAN) technology that can connect IEEE802.11 (Wi-Fi) hotspots with each other and to other parts of the Internet and provide a wireless alternative to cable and DSL for last mile (last km) broadband access. However, the field of uses is broader and overlaps those for mobile WAN (wide area networks) and WLANs. IEEE 802.16 provides up to 50 km (31 miles) of linear service area range and allows connectivity between users without a direct line of sight. Note that this should not be taken to mean that users 50 km (31 miles) away without line of sight will have connectivity. Practical limits from real world tests seem to be around "3 to 5 miles" (5 to 8 kilometers). The technology has been claimed to provide shared data rates up to 70 Mbit/s, which, according to WiMAX proponents, is enough bandwidth to simultaneously support more than 60 businesses with T1-type connectivity and well over a thousand homes at 1Mbit/s DSL-level connectivity. Real world tests, however, show practical maximum data rates between 500kbit/s and 2 Mbit/s, depending on conditions at a given site.
It is also anticipated that WiMAX will allow inter-penetration for broadband service provision of VoIP, video, and Internet access—simultaneously. Most cable and traditional telephone companies are closely examining or actively trial-testing the potential of WiMAX for "last mile" connectivity. This should result in better price-points for both home and business customers as competition results from the elimination of the "captive" customer bases both telephone and cable networks traditionally enjoyed. Even in areas without preexisting physical cable or telephone networks, WiMAX could allow access between anyone within range of each other. Home units the size of a paperback book that provide both phone and network connection points are already available and easy to install.
There is also interesting potential for interoperability of WiMAX with legacy cellular networks. WiMAX antennas can "share" a cell tower without compromising the function of cellular arrays already in place. Companies that already lease cell sites in widespread service areas have a unique opportunity to diversify, and often already have the necessary spectrum available to them (i.e. they own the licenses for radio frequencies important to increased speed and/or range of a WiMAX connection). WiMAX antennae may be even connected to an Internet backbone via either a light fiber optics cable or a directional microwave link. Some cellular companies are evaluating WiMAX as a means of increasing bandwidth for a variety of data-intensive applications. In line with these possible applications is the technology's ability to serve as a very high bandwidth "back-haul" for Internet or cellular phone traffic from remote areas back to a backbone. Although the cost-effectiveness of WiMAX in a remote application will be higher, it is definitely not limited to such applications, and may in fact be an answer to expensive urban deployments of T1 back-hauls as well. Given developing countries' (such as in Africa) limited wired infrastructure, the costs to install a WiMAX station in conjunction with an existing cellular tower or even as a solitary hub will be diminutive in comparison to developing a wired solution. The wide, flat expanses and low population density of such an area lends itself well to WiMAX and its current diametrical range of 30 miles. For countries that have skipped wired infrastructure as a result of inhibitive costs and unsympathetic geography, WiMAX can enhance wireless infrastructure in an inexpensive, decentralized, deployment-friendly and effective manner.
Similarly,please refer various websites and you can get more information.
Best wishes for successful completion of the paper.
Tht was a fabulous description given on Wi-Max.But sir,i wud like to have some examples with their descriptive diagrams or their circuitry diagram,so tht i can be more & more clear to explain the paper.
Hope u will again support me in the same way as u supported me before.
