Previous in Forum: Copper and Copper Alloy Piping Standards   Next in Forum: Yellow Pipes - Certainteed
Desalination Plant Design
10/15/2006 9:08 PM
I've done research on various plant designs for desalinating seawater and found the two most common designs are distillation and reverse osmosis. Assuming cost for the plant and components is neglected but cost for utilities, such as electricity, is the only restraint, what one would be most efficient at turning a profit based on producing at least 1 million gallons per day of fresh water?
Or would a hybrid of the two be the best route to take? if so, what order would seawater be processed?
Good Answers: 120
Re: Desalination Plant Design
10/17/2006 12:23 AM
Per Ardua Ad Astra
10/17/2006 8:09 AM
To produce a million gallon per day....the biggest operating cost in a Flash Type Desal is steam. A plant litterally needs upwards of 250,000 lbs/hr of steam. That is achieved with an industrial boiler.
With RO, (I can't say I've seen a million gal/day RO plant) but your big expense is going to be in the acid backwash. This operatation is conducted for every 100,000 to 200,000 FT3 of flow. Acid purchase and disposal costs would be large.
Generally - the industry standard is to tie a desalinization plant into a power gen plant (cogen - for steam and electrical production)
I commissioned one of these facilities for Enron in 1999 in Penuelas Puerto Rico. We used an IDE (Isreali Desal Engineering) 4 stage flash type desal plant (generating 1 million gallons per day of fresh water) and took steam from a combined cycle plant that used 2X Siemens Westinghouse 501F gas turbines and 2x ABB HRSG's.
11/01/2006 11:10 AM
with the plant you commissioned for enron in 1999 in penuelas puerto rico, what kind of set up was used (i.e. flow chart design of equipment). this would be very helpful to me if possible.
11/21/2007 7:49 PM
http://blog.scifi.com/tech/archives/2007/05/04/solar_power_pla.html
here is a possible heat source
08/28/2009 6:06 PM
Use solar to heat the water, then a steam driven electrical turbine to generate power for utilities. The steam will then condense into pure water to be sold! I can envision the whole plant set-up just writing about it.
