Previous in Forum: oxygen gas generation from air   Next in Forum: HP Pump
axial flow compressor
11/17/2008 2:55 AM
Hi.. i want ot make low pressure ( 7 psi g , 400 nmcube to 2000 nmcube per hour) high efficient axial flow blower so help me about technical information , concepts , drawings & much more ....
Good Answers: 183
Re: axial flow compressor
11/17/2008 4:16 AM
The best solution is to buy one. Look in a catalogue for what is offered with your data I am sue you will find a good solution. To build one with a good efficiency and with low noise level it is a complex exercise which will cost more than the one you can buy.
Use google or an other engine for fan manufacturers
Good Answers: 137
11/17/2008 6:24 AM
In principle axial flow compressors are more efficient than centrifugal (modern turbo aero-engines are all axial flow, I believe I'm right in saying) but your application is way too small for axial to be applicable. It's an application for a single-stage high-speed or multi-stage low-speed job. It could be on the small side even for them, perhaps Roots blower is more suitable.
For e.g. sewage aeration, I've never seen axial flow, even on big plants with centrifugals ~ 1000kW each. Maybe axials are used in chemical plants, I woulfdn't know.
BTW I agree with Nick it's a lot easier to buy one than try to make one, any type! Adam Smith would turn in his grave!
Cheers..........Codey
11/20/2008 6:00 AM
Although, Nick name has suggested that you buy one, I would be surprised if an engineer would have actually given you his design for free. Then, of course, I could wrong.
EditorGBAnalysts - Give a boy fish and he will eat may be for a day, but teach him how to fish and he will eat everyday.
Codemaster (1); editorgbanalysts (1); nick name (1)
