Previous in Forum: Hardcoat Anodized in Europe   Next in Forum: Wear resistance SS304 Vs SS316
Grade of material in seamless pipe of ASTM / API / ISO / Indian Standard
11/18/2008 6:31 AM
Gents,
We are going fabricate a Pressure Vessel (sort of gas cylinder) having Diameter 21Inch & length of 10.5 feet with both side dishends. Test pressure is approx.3500 psig.
The requirement is as below:-
Mechanical properties:
Standard codes Models of steel tubes Tensite strength(MPa) Yield strength(MPa) Yield ration Elongation(%) Absorbed-in-fracture energy(J) Hardness
Q/321088HGB3 4130X 725~865 485~735 ≤0.85 ≥20 -40℃≥40 195~269HB
Chemical composition:
Standard codes Models of steel tubes Chemical compositions(%)
C Si Mn P S Cr Ni Cu Mo V
Q/321088HGB3 4130X 0.25~0.35 0.15~0.35 0.40~0.90 ≤0.020 ≤0.010 0.80~1.10 ≤0.25 ≤0.20 0.15~0.25 ≤0.08
Can anyone suggest Grade of material in seamless pipe of ASTM / API / ISO / Indian Standard????
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: Grade of material in seamless pipe of ASTM / API / ISO / Indian Standard
11/19/2008 11:29 AM
It seems your question is related to SAE 4130X steel which is just specified for gas cylinders and if I think it was approved by US DOT for such use.
Just google SAE 4130X.
Kind regards
Good Answers: 243
11/19/2008 1:04 PM
You plan on heat treating this to get the properties, Right?
Anyone suggesting a grade would be the engineer of record. Getting engineer of record over the internet in a public forum seems ???
I note that your table specifes Vanadium rather than Aluminum for Grain size. Do you know Why?
Wall thickness?
You want to find 21inch diameter 4130 seamless pipe?
Hopefully Abdel Halim Galala will chime in on this one.
i'll pass.
milo
11/19/2008 6:59 PM
Perhaps I have misunderstood. If you go to www.chesterfieldcylinders.com, you will find there a company that specialises in manufacturing large diameter cylinders, in accordance with whatever standard you require. To attempt to manufacture a cylinder like this when there are people who specialise in such tasks seems to me to be highly risky, since that cylinder at high pressures is a bomb. Or perhaps you have already considered this route of manufacture ?
Re: Grade of material in stainless steel seamless pipe of ASTM
12/11/2008 10:38 PM
Dear Sir/Madam,
This is Spark Guo from Shanghai Juxing Industrial Co.,Ltd, which is specialized in manufacturing Stainless Steel Products.
we have more than 15 years exportation experience ,and have clients all over the word.
Our products include Stainless Steel Seamless pipes, Stainless Steel Welded pipes,Stainless Steel Pipe Fittings,etc.
1.Specification: O.D: NPS 1/8" to 20" ; Wall Thickness : Sch5s,10s,40s,80s.
2.Standard: ASTM/ANSI,JIS,DIN,GB,etc.
3.Material Grade: TP304,TP304L ,TP316L,TP310S,TP321,201,301,etc.
4.Other sizes can be manufactured according to customer's requirement.
Our company have passed through many international association certificates:ISO 9001:2000,(TUV)PED, BV,etc.
If you have interest in our products ,please kindly infrom us for more details.
Thanks&Best Regards!
Spark Guo
2008-12-11
SHANGHAI JUXING INDUSTRIAL CO.,LTD
Add:Room 2701,Zhongda Square,NO.989 Dongfang Road,Shanghai,China
Tel:0086-21-68763900
Fax: 0086-21-68763615
Cell Phone:0086-15021666808
Website: http://www.jspipe.com
Contact Person:Spark Guo
Email:spark_guo@jspipe.com
Msn: super.guo@hotmail.com
Register to Reply 4 comments
Anonymous Poster (1); Kwetz (1); Milo (1); Raknruin (1)
