Hi ,
Good day falls to everybody!
We're using lead free solder bar(SAC 305/ NP 303) for our soldering process:
Soldering process: After enamel coating removed, Copper wire is dipped into the solder pot & get soldered.
But one of our customer found that the solder coating over the cu wire contains "Pb" above 1000ppm . But we've the confirmation (Test results) from our solder bar supplier that the Pb content is below 1000ppm.
We don't found any suscipcious in our process line except one thing.
In our soldering process, we're using the solder pot which have'been using almost six month without cleaning.Here i've eye whether the lead content in the solder pot get increased due to the absence of cleaning.
Could anybody confirm whether my above doubts is correct or In which place all went wrong???
Your quick valuable response will make me free from the critical position.
Hari
