File: C-710/17/07
(continued)
Plating Material PropertiesTinSilverNickelMaximum ServiceTemperature (typical)
150 C
250 C
450C
Electrical Conductivity
15% that of copper
106% that of copper
25% that of copperCrimp ContactResistance
Good but can
deteriorate over time
Excellent
Good but can
Solderability
Good but can
Excellent
Requires active flux
Conductor Coatings
Metal coatings are often applied to the surface of individual wire strands in electrical
conductors to improve solderability, reduce oxidation (corrosion) or improve electrical
properties at high frequencies. Three of the most common coating
(plating) materials used with copper conductors are tin, silver and
nickel. A coated conductor with 7 individual strands is illustrated at
right (coating thickness exaggerated for clarity). Decades ago metal
coatings were also used to provide easy stripping of the insulation,
i.e., to keep the insulation from sticking to the conductor. Improved
insulation materials have made that practice unnecessary.
Coating MaterialsTin is the most common coating material. Conductors coated with tin are usually referred
to as "tin plated" or simply as "tinned" conductors. Tin effectively prevents oxidation at
temperatures up to about 150C, but is not as electrically conductive as copper. At higher
temperatures, silver is often used to minimize oxidation in spite of its high cost. Silver is
also used for high frequency applications where silver's excellent electrical conductivity
and the skin effect
1
work together to reduce impedance and attenuation. At temperatures
above 250C, nickel is often used. Although it is also a relatively poor conductor of
electricity, nickel provides effective protection from oxidation up to approximately 450C.
A summary of plating material properties is shown in the table below.
1
Skin effect is an electrical phenomenon in which current tends to flow on the outer surface of a conductor.
There are several ASTM standards on that matter, and several copper grades (usually non alloyed) soft and with many "annealings" just for electrical purposes.
Her you have a link to the ASTM list of content of Volume 02.03 which is fully dedicated to electrical conductors.
You'll find that there are several "strand types".
