Want to build a 20' Wide X 60' Long X 20' High structure. Bottom 12' will be used for boat and vehicle storage in a flood plain along the Ohio River. FEMA requires the floor of a living area to be above the flood plain. The bottom 12' of this structure will be in the flood plain but the water has not gotten to even the bottom of this proposed structure in the last 50+ years. Want to build with steel so if flooded no warping or swelling of wood, plus strength. Structure will be used for a summer/weekend home. Structure will be covered with Structural Insulated Panels (SIP's) 40' long, cut to 20' long for the sides and run lengthwise with a 10' cantliver overhang on each end of the living area floor as well as the roof which will be flat and covered with rubber. Wind load will be 90 MPH and snow load will be 25". Support columns will be spaced evenly along the long sides of building with floor and roof support spanning 20'. Supporting structure will resemble a squared capital letter "A". Supporting columns and supporting span unit/assembly will be spaced a maximum of 10' and may be placed as close as 4'.
What would be my best choice(s) for the 20' long support columns? "C","I","H","Z" beams? What size and thickness would be required?
What would be my best choice(s) for the 20' wide/long span for the floor and roof? "C","I","H","Z" beams? What size and thickness would be required?
Have talked to metal building manufactuers and they want to use a sloped roof, which I do not want to use. Some do not want to build the loft/floor, they call it a two story building. Most want to use tapered support columns which would make it more difficult to finish the living area. Don't want an overkill but do not want anything not safe. Is this simple enough to figure or hire a civil engineer? There are no building and zoning requirements to meet, only the height of the living area floor above the flood line as required by FEMA.
