Previous in Forum: ESAB LAG 400 Input voltage   Next in Forum: Vegetable Heating Oil
8 comments
LG LCD Monitor display Problem
11/22/2008 9:46 AM
I am using LG 19" LCD Monitor for the past 11 months it is a wide screen flatron 5000:1 digital fine contrast. while working with the PC suddenly the monitor colour changed in to pink and after some minutes it also turned in to RED.what may be the problem.can any body help to me over this issue,or i have to contact the vendor. Regards Anancha Perumal
Re: LG LCD Monitor display Problem
11/22/2008 10:39 AM
Your backlights may have gone out, or the ballast for them.The usual mode of failure is the tubes go first, which overloads the ballasts which then fail.
The backlights are usually very small (4 mm) diameter flourescent tubes,about the diameter of uncooked spaghetti.
Google for LCD backlights,there is plenty of info out there, and companies that provide parts.
11/22/2008 11:28 AM
Or it may not be your monitor - your video card could have failed.
11/22/2008 2:36 PM
Swap it out for another monitor to test your video card.
Good Answers: 120
11/23/2008 12:27 AM
it sounds like a pin or wire failure, that allows the red component to dominate.
reseat the connector at both ends
Per Ardua Ad Astra
11/23/2008 1:35 AM
Most likely cause is a loose cable. Check VGA cable connection. 99% chance it will solve the problem. If it does not as suggested by others check VGA card.
sisira
11/23/2008 1:39 AM
Check your video card by using another monitor, if it works OK, take your LG monitor back for warranty replacement. Don't mess with it in any way because they can use that as an excuse to void the warranty.
Randy
"don't be so open minded that your brain falls out" unknown
11/23/2008 3:56 AM
Sorry not to agree on with others, but in my experience in most cases it's only a cable contact problem.
Béla
Good Answers: 22
11/23/2008 5:48 PM
Yes, agree, its most likely the cable, or the connector on one end. Try another cable, & try the monitor on another PC first, b4 going for the faulty monitor solution.
We've just had this exact problem. Thought it may have been the monitor, but then realised we could resolve the problem by holding the VGA lead at the back of the monitor, "at a certain angle", & the colour was restored to normal. New Cord - Problem solved!
(Assuming that the VGA Cable is plugged into the back of the monitor)
Register to Reply 8 comments
Anonymous Poster (4); aurizon (1); OldTechNewToys (1); Randyl (1); Sisira (1)
