Hi all,
I have an ESAB LAG 400 MIG welder that I am quite fond of. Having recently moved to a new property that does not have three phase supply, I am looking to run the welder on single phase (as I only ever weld light material).
It has a primary 3ph transformer, a diode bridge and then the secondary transformer. The output to the wire feed is 42V.
Looking at the circuit diagram, I'm thinking that I should be connecting the three input connections together but then I have nowhere to connect the neutral! Or can I loop out the three input transformers to run in series.
The best option is to do nothing until somebody with the specific knowledge of this machine can get back to me with a 'yes, you can' or a 'no you can't' type of answer!
Any help would be appreciated as, out in the bush, 3ph isn't an option!
