Previous in Forum: Material Engineering Software   Next in Forum: Element 118: If You Blinked, You Missed It
Corrosion Resistant Threaded Rods
10/17/2006 9:41 AM
We would like to use corrosion resistant steel full threaded rods for pipe supports.
Electrogalvanised is not suffiencient due to high humidity in the area.
Hot dipped galvanised is not possible due to threading at site which will give out zinc coating.
Do you any alternative coating which we can use on these threaded rods?
Re: Corrosion Resistant Threaded Rods
10/18/2006 12:04 AM
Stainless steel should be available as threaded rod - 304 grade may corrode but 316 grade should be ok.
Andy
10/18/2006 12:38 AM
Look at www.glubak.com
This will render even rebar rustproof --even in a corrosive environment.
It is cheaper and easier than epoxy coating.
10/18/2006 9:54 AM
We have used wheatering steel in power transmision towers and power stations switchyards in a salty and wet enviroment at the Panama Canal. If you send me an e-mail I may send you a copy of STRUCTURAL STEEL SUPERSTRUCTURES.pdf.
my mail llizarraga@pancanal.com
This document has a lot a valuable information that you may use for choosing your threaded rod material. Good luck
10/18/2006 6:38 PM
use mild steel and give them a finishing coating of epoxy
cut to remove if you ever need to
think laterally
10/19/2006 11:13 AM
Absolutely, We have used that aproach several times and even covering the steel parts with grease works great, but as always, you have to design your application acordingly with your enviroment and tech. specs. Regards
Luis
Anonymous Poster (2); llizarraga (2); tesla-was-right (1)
You might be interested in: Grounding Bars and Rods, Threaded Inserts, Threaded Rod
