Previous in Forum: Corrosion Resistant Threaded Rods   Next in Forum: Ternary Alloy Problems
Friend of CR4
Element 118: If You Blinked, You Missed It
10/17/2006 11:50 AM
Yesterday, a team of scientists from Russia's Joint Institute of Nuclear Research and Livermore National Lab in California succeeded in creating Element 118. Element 118, the first man-made noble gas, is the heaviest element ever created in a lab. The unnamed element (atomic # 118) maintained its structure for less than one-thousandth of a second before decaying into element 114, then element 112, and then finally splitting in half.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
The Engineer
Good Answers: 129
Re: Element 118: If You Blinked, You Missed It
10/17/2006 1:47 PM
That's cool. It sounds like a short amount of time but they can find out a lot about an element in a millisecond. Many reactions occur in picoseconds or femtoseconds, which is a million, or a billion times faster than the lifetime of this element. It's good research because it gives insight into the internal structure of atoms and it tests whether these new elements fit well into the periodic table (in terms of properties).
Hobbies - HAM Radio - New Member Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member
10/18/2006 2:47 PM
I am not a physicist, obviously, so this may seem a stupid question, but is it possible that somewhere in the universe there are other elements that do not exist on earth, yet are stable, or at least have one stable, or very long half-lived isotope? Or are these heavy elements, by their very nature unstable and extremely radioactive?
Also, how do we know that 118 is a "noble gas", just because it falls into that column on the Periodic Table? Existing for such a short period, how do we know that it is "noble", unable to form compounds with other atoms, or that is it woud even even be a "gas", at what we would consider a "normal" temperature and pressure.
"What, me worry?" Alfred E. Neuman
Good Answers: 32
12/03/2006 7:03 PM
To your first question, yes, it is possible that other elements exists elsewehere.
To your second, noble gases is a phrase used when the elements were discovered. No compounds of these elements were known. Since then, compounds have been made with these elements. The new element would have just fit into the periodic table under these gases, because of it's electronic structure.
Gas is a relative term. At high enough temperatures, every element is a gas.
Register to Reply 3 comments
Bayes (1); STL Engineer (1); Tad (1)
You might be interested in: Lab-on-a-Chip (LOC) Devices
