Previous in Forum: planning circuit   Next in Forum: Transformer
SMPS
11/23/2008 4:39 AM
how can i repair faulty switched mode power supply(smps)
how can i inspect 1-it pwm IC
2- Transformer
Indonesia - Member - Member from Indonesia Hobbies - Fishing - New Member Engineering Fields - Electrical Engineering - Member
Re: SMPS
11/23/2008 3:35 PM
If i repair a smps, i can inspect the ic by this step:
1. Find data sheet for the ic.
2. Give dc supply to vcc ic with another power supply.
3. Use oscilloscope to see output from ic.
If there's signal from ic output same with data sheet, so the ic is ok,
To test transformer, usualy i use flyback tester.
Fear of God is the beginning of knowledge, God bless you.
Re: SMPS
11/25/2008 2:27 AM
thanks for your help
what is a flyback tester (can i build one)?
Re: SMPS
12/06/2008 1:47 PM
Its a simple fly back tester, I believe you can built it, i use this circuit to test all of high freq transformer like SMPS transformer or fly back, this circuit is an astable multivibrator with about 90Khz freq, 12 vdc as vcc.
To check SMPS transformer or fly back you should reverse the input and output, i mean you use secondary 12v or 24v out put as input, give 12 or 24 output pin 12 vdc and another pin to output this circuit, when you turn on this circuit, use ac volt meter to measure primary, it should be come out 80 - 480 vac, depend to transformer spec, if there is no voltage come out from the primary transformer, so the transformer is damage, you can also measure another pin with the same step.
BTW transformer at the figure above is the transformer that you want to check.
Register to Reply 3 comments
You might be interested in: PWM Amplifier Chips, DC Motor Drives, LED Drivers
