Previous in Forum: SMPS   Next in Forum: far fm radio
Transformer
11/23/2008 4:43 AM
how i inspect if the ferrite transformer can't supply it's power?
is there transformer (or coil) for suppling high current?what it's name and idea?
Good Answers: 12
Re: Transformer
11/25/2008 6:40 PM
There are many types of switch mode supplies. I highly recommend you research such things on the web. Google switch mode power supplies, or look in Wikipedia. On the transformer, I would remove it and look for continuity across the primary and the secondary with an ohm meter. If it is a high current output, the resistance will be very low.
###WARNING! SMPS do have lethal voltages inside!! These can KILL!!###
Also, the questions you ask are like "My car is broke!! How do I fix it?"
What do you put into this machine? 120v 60HZ? 240v 50Hz? 12v car battery?
What do you expect out for voltage and current. We need this info before we can even begin to help you.
I notice a radio call imbedded in your name. If you are in Bremerton, let me know.
Sincerely
Bill
