Previous in Forum: Breather Valve Setting   Next in Forum: Whats is a Magnehelic Gauge?
India - Member - New Member Engineering Fields - Instrumentation Engineering - New Member
Reed Switches and Pneumatic Cylinders
11/23/2008 9:43 PM
I am familiar with Reed switches used with the pneumatis cylinders.
With reed switch we are able to get only one position of the cylinder piston.
Is there any other sensor which is able to provide us with analoge o/p corresponding to different positions of the piston ??
Shameem
Pathfinder Tags: reed switch
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: Reed switch
11/24/2008 12:18 AM
Sure--proportional valves with temposonic probes and PID loops. Lineal positioning systems.
Check Bosch or Moog for the valves.
Check MTS for probes.
Or http://www.pawtaw.com/ for both.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
Good Answers: 88
Re: Reed switch
11/24/2008 1:18 AM
Nice stuff. You buyin' ?
Good Answers: 88
Re: Reed switch
11/24/2008 1:37 AM
For how many other positions of the cylinder? Few? Many? With what accuracy do you need to know the position? Must the position information be analog (ie, a voltage, perhaps)? Can it be digital?
Your solution's price depends heavily on how you answer these questions. Think about exactly what you need and why you need it. Beyond that and you could end up spending a lot of money you'd probably rather keep.
(Note. The following is not addressed to you. You may skip this part if you wish: There are always arbitrarily sophisticated, expensive and overly complicated solutions to any problem. I mean, who doesn't have a few hundred thou laying around for just this purpose? Great, helpful response. The OP is now way ahead. )
Re: Reed Switches and Pneumatic Cylinders
11/24/2008 8:15 PM
Perhaps the easiest most reliable way is to use a LVDT with a current or voltage output. One manufacturer of LVDTs is: http://www.schaevitz.com/ another is http://www.macrosensors.com/
There are also magnetostrictive devices like the Temposonics: http://www.mtssensors.com/technology/how-magnetostriction-works/index.html
Possibly the cheapest way is to use a linear potentiometer. Like this: http://www.bourns.com/pdfs/bourns_lmp_apno.pdf
Other solutions which may be acceptable are: Cable actuated like here: http://www.unimeasure.com/
There are many different types of linear sensors suitable for use with air cylinders. It would help to know the environment where the equipment will be operating, the length of the stroke, speed requirements interface desired and any cost considerations.
I have even seen a pneumatic sensor which used a tapered needle in an orfice fed through a flow restrictor. The tapered needle was connected to the oposite end of the air cylinder and the position was sensed by monitoring the pressure of the air up stream of the tapered needle arangement. The position display was a specially calibrated pressure guage. As the cylinder pulled the load (retracted) the opposite end of the piston shaft with the needle entered the variable valve body causing the pressure to rise as the needle blocked the air bleed.
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
11/25/2008 5:51 AM
Try a feedack valve positioner. Search Google for detailed info. This will give you an exact position relative to a linear motion of your piston.
"Memorize the calculations, you look like a fool searching your notes while teaching class"
11/25/2008 10:05 AM
Bimba and TRD make actuators with LRT's in them providing position feedback throughout the length of stroke.
See http://www.bimba.com/Products/PositionControl/PositionControlSystemPCS/
or http://www.trdmfg.com/Products/Balluff/
Bimba have a new, non-contact probe available which will provide better life expectancy than a contact probe. TRD use a Balluf non-contact probe.
Position feedback is available in Volts or mAmps.
If you are in Canada, we can help. www.cowper.ca
Regards,
Gren Cowper
11/26/2008 8:42 AM
Sir, try a search of Baluff for a reasonably inexpensive and accurate analog solution to your displacement issue.
Regards
Register to Reply 7 comments
Anonymous Poster (2); jcchiefeng (1); Kilgore Trout (1); Turbotroll3 (1); user-deleted-13 (2)
