Previous in Forum: RVP gauge   Next in Forum: Reed Switches and Pneumatic Cylinders
Breather Valve Setting
11/23/2008 12:56 PM
Dear Frnds.
We have one Breather Valve Weight type ,With Set Point As 50 Psig/-0.9" WC With Nozzle size as 4.0" for the Drain Vessel
Our Vendor has refused to quote for the above mentioned SP, as its unavailable for that range,
I want to know what alternatives are available to resolve dis
Regards
Jose
Re: Breather Valve Setting
11/24/2008 8:25 AM
For 50.0 Psig use a regular safety relief valve(spring loded) and use the weight loaded device for vacuum protection.
If you don't know where you are going,you are bound to get there
