Previous in Forum: Types of Level Transmitters   Next in Forum: Breather Valve Setting
RVP gauge
11/23/2008 1:03 AM
Can anyone tell me where I can find an RVP (Reid Vapour Pressure) gauge 0-15 psi with 0.05 graduations. Thanks in advance.
Good Answers: 68
Re: RVP gauge
11/23/2008 10:50 PM
Hello mogambo:
Here are two sites which do the guages you asked for. Good luck.
http://www.koehlerinstrument.com/products/311-250-001.html
311-250-001 Reid Vapor Pressure Gauges
Re: RVP gauge
02/13/2009 2:04 PM
It is the parameter to determine the grade of fuel / naphtha.not a gauge like for pressure or temperature.
iak
Good Answers: 68
Re: RVP gauge
02/13/2009 3:10 PM
Hello khania58:
Can you tell me if you have enough information? It would help if you could say if this a hand-held device, or something that is is measuring 'atmosphere' which would be harmful to you if you were open to it? Is Naphtha the only volatile 'lite' product you want info as to its density?
Take care.............
Re: RVP gauge
02/13/2009 3:32 PM
I mis understood the question.To measure this property of fuel in the LAB they may be using pressure gauge which is more robust,reliable.To measure this property online in the refineries analyzer is used not the gauge.If u still have querry may contact ABB ONLINE PROCESS ANALYZER.
for the pressure gauge above link is right.
iak
Register to Reply 4 comments
