Previous in Forum: Mechanical Engineering   Next in Forum: Energy conservation
Fabrication Engineering
11/25/2008 5:38 AM
how to decide which grade material to be used for fabrication?
Good Answers: 61
Re: Fabrication Engineering
11/25/2008 10:06 AM
Fabrication of what?
Do it once and do it right
11/25/2008 11:17 AM
Wow - I agree more information is required to give a decent answer.
However, I will just throw out there a few of the considerations from material selection:
  • corrosion/oxidation
  • strength (at temperature)
  • wear resistance
  • ease of fabrication
  • cost
  • material availability
  • applicable codes/standards
  • thermal/electrical properties desired
  • fatigue
  • weight
  • creep resistance
  • vibration damping
  • toughness
11/25/2008 5:00 PM
............ I forgot to mention - a good reference for materials can be found here:
MMPDS-01 (CAUTION - large size 74MB)
http://www2.tech.purdue.edu/at/courses/at308/Technical_Links/MMPDS/MMPDS-01.pdf
OR you can search by chapter (smaller portions) here:
http://www.grantadesign.com/userarea/Mil/mil5.htm
Register to Reply 3 comments
