Previous in Forum: Fabrication Engineering   Next in Forum: Questions about coupling failure
8 comments
Energy conservation
11/25/2008 9:59 AM
Can anyone suggest good websites/blog sites for energy conservation?
Re: Energy conservation
11/25/2008 12:19 PM
11/26/2008 12:41 AM
Hey, does MUKULMAHANT know you stole his avatar?
(I think there is another imposter out there as well)
11/26/2008 9:47 PM
How To Reduce Your Energy Bills / Energy Conservation Begins at Home
Imagine leaving a window open all winter long -- the heat loss, cold drafts and wasted energy! If your home has a folding attic stair, a whole house fan or AC Return, a fireplace or a clothes dryer, that may be just what is occurring in your home every day.
These often overlooked sources of heat loss and air leakage can cause heat to pour out and the cold outside air to rush in -- costing you higher heating bills.
Air leaks are the largest source of heating and cooling loss in the home. Air leaks occur through the small cracks around doors, windows, pipes, etc. Most homeowners are well aware of the benefits caulk and weatherstripping provide to minimize heat loss and cold drafts.
But what can you do about the four largest "holes" in your home -- the folding attic stair, the whole house fan or AC return, the fireplace, and the clothes dryer? Here are some tips and techniques that can easily, quickly and inexpensively seal and insulate these holes.
Attic Stairs
An easy, low-cost solution to this problem is to add an attic stair cover. An attic stair cover provides an air seal, reducing the air leaks. Add the desired amount of insulation over the cover to restore the insulation removed from the ceiling.
Whole House Fans and AC Returns
An easy, low-cost solution to this problem is to add a whole house fan cover. Installed from the attic side, the whole house fan cover is invisible. Cover the fan to reduce heating and air-conditioning loss, remove it when use of the fan is desired.
Fireplaces
A recent study showed that for many consumers, their heating bills may be more than $500 higher per winter due to the air leakage and wasted energy caused by fireplaces.
An easy, low-cost solution to this problem is to add a fireplace draftstopper. Available from Battic Door, a company known for their energy conservation products, a fireplace draftstopper is an inflatable pillow that seals the damper, eliminating any air leaks. The pillow is removed whenever the fireplace is used, then reinserted after.
Clothes Dryer Exhaust Ducts
An easy, low-cost solution to this problem is to add a dryer vent seal. This will reduce unwanted air infiltration, and keep out pests, bees and rodents as well. The vent will remain closed unless the dryer is in use. When the dryer is in use, a floating shuttle rises to allow warm air, lint and moisture to escape.
If your home has a folding attic stair, a whole house fan, an AC return, a fireplace, and/or a clothes dryer, you can easily, quickly and inexpensively seal and insulate these holes.
Mark D. Tyrol is a Professional Engineer specializing in cause and origin of construction defects. He developed several residential energy conservation products including an attic stair cover, an attic access door, and is the U.S. distributor of the fireplace draftstopper. To learn more visit www.batticdoor.com
12/02/2008 10:06 AM
Thank u but I want to know names of some important web sites/blogs if anyone using.
Thanks once again.
06/30/2009 11:23 PM
Check out www.stophomeenergyloss.com . I am no expert, but I have been working to reduce my home energy loss by applying the 'whole house' method to conserving energy. The experience and results have been fantastic. Not only have I reduced my energy loss by 23% (35% when I compare first quarter 2008 vs 2009..whole house method still working!) but I have greatly improved the overall comfort of my home.
I decided to document my experiences and how I did it in a series of small eBooks. It's free...really...no email required..nothing. I have a huge pile of notes that I am still working through so I don't have everything document yet, but I am trying my best! Let me know what you think.
John M
07/27/2010 12:26 PM
This game will make you more aware of your energy use.
http://nexus.kumagames.com/portal/welcome/forum
09/21/2010 2:54 PM
CT-TEXAS.COM We just dropped the roof temperature of a refrigerated metal building by 76 degrees. 186 degrees down to 110 degrees on a 105 degree day.
11/12/2010 3:30 PM
Register to Reply 8 comments
Anonymous Poster (5); gohiljayesh (1); halskinner (2)
