Previous in Forum: Energy conservation   Next in Forum: All-Ports Blocked / Closed Center Valve
Questions about coupling failure
11/25/2008 10:22 AM
What are the probable reasons of crack on spider coupling?
What reasons of failure of coupling Half (made of C.I) between vacuum pump and motor?
Good Answers: 101
Re: Questions about coupling failure
11/25/2008 11:22 AM
Possibly improper alignment between the pump/motor?
hard starts/stops?
is the coupling properly sized for the application?
improper spacing between the pump/motor?
Most of the failures i have seen are a direct cause of improper installations, but on occasion you might find a faulty coupling/insert from the manufacturer.
Good Answers: 143
11/25/2008 12:44 PM
Please tell us some details. What material was the spider made of? Was the spider correctly sized for the torques in your application. What is the misalignment? Did you really have cast iron?
