Hi,
In an application, I use a spring applied/pneumatic return cylinder. I need to be able to stop my cylinder at the fully retracted position. Hence, I use a all port blocked (closed center valve).
However, I notice not only the cylinder slowly creeps out when it is stopped at its fully retracted position, but also slowly creeps in when it is already fully extended. I was told by the manufacturer that this type of valve leaks a little bit and hence, creeps in or out.
Could anyone give any advise on how to solve this problem?
Thanks
Kind regard,
Chin
