Previous in Forum: Pressure Vessel Material   Next in Forum: Pneumatic / DC Drivers for Assembly
Welding Electrodes for nicle material
11/25/2008 11:23 PM
HI!
Can anybody suggest what kind of electrodes should be used for material contains high percentage of Nicle?
Thnks
Re: Welding Electrodes for nicle material
11/25/2008 11:40 PM
What alloy EXACTLY are you trying to weld?
11/25/2008 11:57 PM
We are having a slot in MS Rod which is having high percentage of Ni. we have to fill by welding.
11/26/2008 12:29 AM
Hmmmmmmmmmm ................... I don't suppose you know more about this MS rod?
If you know there is high Ni - how much? Are there any other elements present? Molybdenum, Chromium, ...........?
Take for example the case IF your MS rod is AISI 4340 - it can be welded, however, you need to follow proper preheat and post weld heat treatment. And it should only be performed on 4340 that has been annealed or normalized.
So please tell as EVERYTHING you know about this MS rod.
11/25/2008 11:40 PM
Try a rod called "Supermisselweld". That's realy its name.
12/14/2008 9:05 AM
It sounds as if you need to weld stainless. If so; a 308-16 rod will do
Tell 'em what they need to hear; not what they want to hear!
Anonymous Poster (3); gadgetmaker (1); noshorts (1)
