Previous in Forum: Wanted: Wires for Embedded Electric Coils   Next in Forum: materaial balence question
Shift and Rotate Functions in PLCs
11/26/2008 1:19 AM
What is the application for the shift and rotate function in PLC? I always do not know where can i apply on it? Any suggestion?
Re: Shift and rotate function in PLC
11/26/2008 2:57 AM
Handy for converting 00001, 00010, 00100 etc. to 1,2,3 etc.
Why didn't you reply on your previous thread?
Good Answers: 68
Re: Shift and Rotate Functions in PLCs
11/27/2008 1:11 AM
Hello vince_02brad@yahoo.co.uk:
It seems you are a newbie to CR4. Welcome and good luck. I hope you find this site of use.
http://www.toolingu.com/class-450370-shift-registers.html
Take care......................
11/27/2008 8:08 AM
One application I have used shift for was when filling a series of tanks, one at a time in a predefined order. I used a bit to keep track of the active tank. When the time was up for filling that tank I shifted the bit which activated the next tank.
Do this. Don't do that. Can't you redesign?
12/01/2008 8:49 AM
I often use these instructions for programming packaging and inspection machines. As a part is indexed down a line, it's position is tracked, and pass/fail status is set at inspection positions.
Register to Reply 4 comments
andrew_ward (1); babybear (1); billg (1); JohnDG (1)
