Previous in Forum: Temperature Transmitters   Next in Forum: Level measurement of Viscose in closed tank
PI converter
11/27/2008 8:46 AM
How pressure to current converter works?
explain with diagram.
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: PI converter
11/28/2008 9:32 AM
Here is a copy (minus the diagrams) of Microchip Technology, Inc., AN695 product. This may help you understand the electronic circuits.
INTRODUCTION
Pressure measurement devices can be classified into
two groups: those where pressure is the only source of
power and those that require electrical excitation. The
mechanical style devices that are only excited by pressure,
such as bellows, diaphragms, bourdons, tubes or
manometers, are usually suitable for purely mechanical
systems. With these devices a change in pressure
will initiate a mechanical reaction, such as a change in
the position of mechanical arm or the level of liquid in a
tube.
Electrically excited pressure sensors are most synergistic
with the microcontroller environment. These style
of sensors can be piezoresistive, Linear Variable Differential
Transformers (LVDT), or capacitive sensors.
Most typically, the piezoresistive sensor is used when
measuring pressure.
This application note will concentrate on the signal conditioning
path of the piezoresistive sensing element
from sensor to microcontroller. It will show how the
electrical output of this sensor can be gained, filtered
and digitized in order to ready it for the microcontroller's
calibration routines. This theoretical discussion will be
followed with a specific pressure sensing design that is
specifically designed to measure barometric pressure.
PIEZORESISTIVE PRESSURE
SENSORS
The piezoresistive is a solid state, monolithic sensor
that is fabricated using silicon processing. Piezo means
pressure, resistance means opposition to a DC current
flow. Since piezoresistive pressure sensors are fabricated
on a wafer, 300 to 500 sensors can be produced
per wafer. Since these wafers generate a large number
of sensors they are available on the market at a
reduced cost as compared to mechanical sensors.
Figure 1:
The resistive wheatstone bridge configuration can have one variable element (a.), two elements that vary
with excitation (b.) or four elements (c.). The piezoresistive pressure sensing element is usually a four element bridge
and is constructed in silicon (d.).
Author: Bonnie Baker
Microchip Technology Inc.
RS1 RS1
RS1
RS2
RS2
RS2
RS4
RS4 RS3 RS4
RS3
RS3
Voltage or
Current
Excitation
Voltage or
Current
Excitation
Voltage or
Current
Excitation
VOUT+
VOUTVOUT+
VOUTVOUT+
VOUT-
(a.) single element bridge (b.) two element bridge
(c.) four element or full bridge (d.) single side of a sandwiched
piezoelectric pressure
"Memorize the calculations, you look like a fool searching your notes while teaching class"
Reply to Forum Thread
