Previous in Forum: Turbocharger speed   Next in Forum: Miller big blue 600x
electric engineering
11/27/2008 10:52 PM
Can 60Hz designed electric kiln use on 50Hz power supply?
Hobbies - HAM Radio - New Member United States - Member - New Member Hobbies - Hunting - New Member
Re: electric engineering
11/27/2008 11:42 PM
Does it have motors or just elements?
Probably, but need more information.
Those who believe in telekinetics, raise my hand --Kurt Vonnegut Jr.
11/28/2008 12:45 AM
electric kiln with element only.
Re: difference frequency
11/28/2008 2:25 AM
Can 60Hz Electric kiln operate by heat elements use on 50Hz
Good Answers: 804
11/28/2008 2:57 PM
Yes.
Good Answers: 804
11/28/2008 3:01 PM
I should add however, there is ususally some sort of control equipment used in operating your kiln. That control equipment must be rated for 50Hz operation, and many components typically used are not. You must investigate the entire system, not just the elements. Assuming you have, and the only remaining issue was the elements themselves, then there is no problem.
11/29/2008 7:44 AM
yea there is relay, transfomer and electronic program controller. so these component also rated for 50 hz operation?
11/28/2008 2:57 PM
Sure, you should be fine--As long as there aren't any fan motors rated for 60Hz. Grainger replacement heating elements I have used are rated for both 50/60Hz. Voltage would be an issue, though.
Hope this helps. K T
Register to Reply 7 comments
Anonymous Poster (1); JRaef (2); Kilgore Trout (2); yhsimon (2)
