Previous in Forum: Difference between UE and E Cables   Next in Forum: Trip current - purpose!!!!
transformer servicing
11/28/2008 11:19 AM
how do i know that a distribution or power transformer of 1000kva is due for servicing and what activites is to be carried out when servicing it. Thank you
Re: transformer servicing
11/28/2008 9:03 PM
do you hope to buy it?
11/28/2008 11:00 PM
Generally for every month & Half yearly we do the checkings.
Monthly: 1. Checking of Silica Gel condition(if it is Oil type)i.e Bule in healthy
condition.
2.Checking of Winding (H.T & L.T) terminal connections.
3.Oil level in the WTI Pocket.
Apart from those yearly once checking of BDV of Oil.
12/01/2008 8:40 AM
Many power generation companies have and do use silica gel canister breathers fitted to the conservator of oil filled transformers, however there is a better solution. Since silica gel is a rigid type desiccant, it is only capable of absorbing approximately 28% of its weight in atmospheric moisture at best. This is why such large silica gel canisters are used, at times I have seen two canisters used that are 60" tall each having a 10" diameter.
Over the past couple of years numerous power companies here in Canada as well as a number of transformer manufacturers abroad are starting to see the benefit of an improved super-polymer based technology that has the capability to absorb 400% of its weight in atmospheric moisture. These new types of breathers can be used independently or in tandem with pre-existing silica gel breather installations. Even when silica gel breathers are currently installed, the benefit is that the silica gel change-out cycle can be extended by 2 to 5 times its normal life-cycle.
This has huge benefits to maintenance and equipment costs because it is a big ordeal to change the silica gel. The worst problem is often silica gel is doped with the highly toxic cobalt(II) chloride a substance often used to indicate maximum moisture saturation by a blue to pink color change. Here is an article about these new types of breathers.
http://www.h2ocontrol.com/documents/Moisture%20Removal%20from%20Transformer%20Oil%20Conservator%20Tanks.pdf
Faith is not blind, it is supremely reasonable.
12/01/2008 12:07 PM
Read the manual that came with the unit
Register to Reply 4 comments
Anonymous Poster (1); cnpower (1); Goodho (1); TeslaFan (1)
