Previous in Forum: Excel Question   Next in Forum: Wanted: Solution-Penetrating Salt Powder
Mini Handycam
11/30/2008 10:17 PM
Hi.all,
I have a Panasonic NVGS-60 Mini Handycam. Every time after recording I have to go photographer shop to convert casette in to CD/DVD. is their any software & accessorries are there thru which I can do this hectic & expensive activity at home only.
I do not have any accessories along with camera.
I have PC at home.Pl.suggest required software /hardware & procedure.
Is this model can be upgradeble so that by using USB cord I can directely connect to PC & get immages copied? like other digital camera.
Pempies
Re: Mini Handycam
11/30/2008 10:51 PM
The USB is for digital stills.
What you need to download your video is a firewire (& card) (which I assume your computer doesn't have) so you will need a system such as this:
http://www.amazon.co.uk/exec/obidos/ASIN/B000ML3UMM/202-8273947-2978256
Re: Mini Handycam
12/02/2008 11:12 AM
Not true, you can also transfer videos via a USB cable too provided the camera has already placed it into a digital format, for instance, like my Sony DigiCam, that can export both stills and movies over a USB 2.0 connection. Mine is not alone in this either....
My camera has a hard disk in it and the films are recoded in digital format......there are plenty of cameras about that recod digitally either on DVDs, Hard disks or tapes....
Firewire is a bit faster (at this moment anyway) till USB3.0 hits the streets in a few years time.....
Where did you get the silly idea that USB can only transport "Stills"? What USB is in fact, it is really only a Data cable and films and stills can be in a data format on the camera, therefore easily copied to a PC or Mac....!!!
You should not make statements that exceed your own personal knowledge, it just makes you look even more gullible than you probably are!!!
It is true that older analog stuff cannot use USB directly unless the cable has a digitizer built into it!!! But that is also possible of course!!
Now you have learnt something new and accurate!!
Good Answers: 97
Re: Mini Handycam
12/02/2008 11:49 AM
Firewire is actually a bit slower but the bandwidth is greater than USB 2.0 and that makes all the difference to me
Good Answers: 97
Re: Mini Handycam
12/01/2008 6:46 AM
Video capture software is what you need and it's free.
Good Answers: 247
Re: Mini Handycam
12/01/2008 11:32 PM
Your camera might have a "firewire" output. If so, then you computer will need a firewire input card if it does not have a firewire port. Video capture software will do the rest -- and there are many varieties.
On the other hand if your camera does not have a firewire output, then you will need an external piece of hardware (or card for you computer) which takes a video input and outputs either via firewire or USB. One such device is called "Broadway." (I have an older external device called a Dazzle Hollywood DV Bridge that works fine.) If you poke around the web for "video capture cards" you will find many.
Re: Mini Handycam
12/02/2008 12:36 PM
I believe this camera uses a mini DV TAPE. According to the technical specs the camera has a digital video out and a USB port. (see link)http://www.amazon.co.uk/Panasonic-NV-GS60-Mini-DV-Camcorder/dp/tech-data/B000Q8I148/ref=de_a_smtd
If you can connect the USB or DV out to your computer you mat be able to copy the information from the tape to your hard drive.
I looked at the reviews on Amazon and found the following...
'You can out put the audiovisual signal by way of a DV Out (No In), Mini USB and composite jack plug (Video, Audio left & right) but there is no S-Video. There are also no DV or USB leads supplied with the camera only Jack Plug. There is also no editing software supplied for your PC.
To see a thorough over view of the product you van down load the user manual from the Panasonic web site, www.panasonic.co.uk. '
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
United States - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
Re: Mini Handycam
12/03/2008 5:12 PM
I have a panasonic camcorder and had the same problem. I use a Sony DVDirect, though mine is an older model and looks a little different. It is basically a DVD burner with a wide range of inputs and does a real time buffer/burn. With my camcorder, I connect my video out cables to the DVDirect and play back my miniDV tape meanwhile the DVDirect is recording the video in. This works with any playback device (VCR, DVD player, video recorder, BETA max, etc.) with video out (S-VIDEO, composite, USB, firewire). The idea being that you can change recording media from an older media like hi8, VHS, etc. to DVD. It does not have inputs for DVI, HDMI, VGA though. It did a good job converting my vacation home movies and old VCR tapes to DVD.
This unit is also stand-alone and does not require a pc.
Register to Reply 7 comments
Andy Germany (1); Anonymous Poster (1); Blink (1); bwire (2); d_m_rosenberg (1); Vandarye (1)
