Previous in Forum: genrotor inqueri   Next in Forum: Transformer Earthing
what is the power & what is the kwh
12/01/2008 7:42 AM
what is kw & kwh
Good Answers: 143
Re: what is the power & what is the kwh
12/01/2008 7:56 AM
kW is kiloWatt (1000 Watt). Note the capital "W". This is power.
kW-h is kiloWatt-hour (1000 Watt-hour). Note the hyphen between Watt and hour; this is recommended but not universally used. This is energy.
Good Answers: 88
12/01/2008 8:33 AM
Also, solanki, 1 watt-second is 1 Joule, also a measure of energy. Therefore 1 kwh is equivalent to 1 Joule/watt-second * 3600 seconds/hour * 1000 watts/kw = 3,600,000 (3.6 x 106) Joules.
12/01/2008 11:31 AM
KW is the unit of electrical power Electric power is defined as the rate at which electrical energy is transferred by an electric circuit. The SI unit of power is the watt. and 1000 watts = 1 KW.
W=IV
where I=Current Folow in Circuit and V=Voltage of Circuit
Whereas
KWH is the unit of energy and
Energy = Power x Time
So if i define KWH it mean power consumed in an hour
Good Answers: 183
12/01/2008 11:41 AM
The Watt is not only for electric powerit is a power unit for all kinds of energy forms: mechanical,thermal, a. s. o.
Good Answers: 804
12/01/2008 1:30 PM
"The Watt is not only for electric powerit is a power unit for all kinds of energy forms: mechanical,thermal, a. s. o."
Depends on where you are.
We use Horse Power (HP) for mechanical power and BTUs or Therms for thermal energy here in the US; helps people to NOT confuse them with electrical power. We do use Watts when discussing heat energy however if it is coming from an electrical source.
12/04/2008 11:09 AM
Yes I agree with you but I am dicuss in electrical parameter.
Register to Reply 6 comments
JRaef (1); nick name (1); PEES (2); TVP45 (1); user-deleted-13 (1)
