Previous in Forum: Very cool control systems   Next in Forum: How Does a SF-6 Circuit Breaker Work?
Deviation in Current Transformer RCT Value while Converting Xmer Rating
12/01/2008 11:35 PM
We are going to convert our 16MVA(33/6.6kV,50Hz) Transformer to 20MVA(33/6.6kv,50Hz) Trasnformer by Converting cooling system from ONAN(Oil Natural Air Natural) to ONAF(Oil Natural Oil Force).
For this change we need to replace our existing CTs at 6.6kv side from 1500/1 to 2000/1 for Metering/Over current E/f protection/Differential protection/Restricted E/f Protection.
Specification of Existing two core CTs for Metering & Xmer Differential
CT No.1
1500/1-15VA,CL 0.5,CORE 2 CTR-1500/1-10VA CL-PS,VK>300V,Imag<30mA AT VK/2,DIFFERENTIAL PROTECTION WITH RELAY DTH31(ALSTOM MAKE),
RCT<=4.75OHM,RATED:7.2KV,25KA,1SEC,BIL:75KV PEAK
Specification of Existing two core CTs for Overcurrent-E/f & Restricted E/f Protection
CT No.2
SINGLE PHASE TYPE,CORE 1 CTR-1500/1-15VA,CL 5P10,CORE 2 CTR-1500/1, CL-PS,VK>150V,Imag<7.5mA AT VK/2,RESTRICTED E/F PROTECTION WITH RELAY FAC14(ALSTOM MAKE),
RCT<3.6OHM,RATED:7.2KV,25KA,1SEC,BIL:75KV PEAK
Here Manufacturer can able to give these CTs with RCT value at 75 deg <= 8 Ohm(against 4.75 Ohm) and at 75 deg <= 6.5 Ohm(against 3.6 ohm) for CT no. 1 and 2 with confirming all other specification.
Can I goahead with this deviation in RCT Value and I would also like to know the impact of this deviation in technical point of view.
thanks
SJ
Re: Deviation in Current Transformer RCT value while converting Xmer rating.
12/02/2008 4:03 AM
dEAR FRIEND,
AS LONG AS YOUR METERING CT IS OF CLASS 0.5 ACCURACY, PROTECTION CT IS OF CLASS 5P10, IT WILL NOT AFFECT ON THE PROTECTION RANGE.
RCT VALUES DEPEND UPON THE CT RATIOS ALSO.
HARRY POTTER.
12/03/2008 12:18 AM
Dear Sir
There more two cores in the CTs which are PS(Special Class) class and used for Restricted E/f & Transformer Differential Protection.will IT(Differ RCT value)affect in these protection ranges.
Suryakant Jatania
Re: Deviation in Current Transformer RCT Value while Converting Xmer Rating
12/03/2008 12:05 AM
Dear Friend
Transformer terminal voltage will drop due to increased pri & sec winding voltage drop ( i*r, i increased by 25% due to increased capacity from 16 to 20 MVA, applied voltage remaining constant ). While cooling will take care of additional heat produced but just check the effect of reduced secondary voltage on connected equipment. If tapping is available then check feasibility of using the lower tap on secondary side to improve voltage, unless you have OLTC. Changing tap in pri. side will also increase iron loss.
Thanks and regards
Ashok Toshniwal, Bangalore, India
12/03/2008 1:25 AM
Dear Mr. Ashok
Pl find herewith Transformer Tap position details for your comments,At present we run transformer with Tap position (OFF-Load-Tap changer)No. 2
TAP POSITION VOLTAGE
1 34650
2 33825
3 33000
4 32175
5 31350
We can go up to Tap position no.5 considering the Voltage Drop.
Regards
Suryakant Jatania
12/03/2008 4:02 AM
Dear Guest ,
From your case thatCore-2 of Both CT-1 and CT-2 are having Ps class which are used for Differential and E/F Ref protections.I also note that new CTs 2000A are having roughly twice RCt value of old 1500A CTsRct ValueI
These higher RCt values of the proposed CTs will give higher Knee point Voltsage (Vk) during fault condition than the knee point voltage produced by old CTS with less RCt values and the increased VK values are more than sufficient for operation of connected protective Differential Relay and Restriced E/F Relay .This highervalue of knee point voltage Vk should not cause any problem for the operation of these relays since giveing higher knee point voltage is always better and will not surely cause saturation of Cts during faults..Only cost of CTs increases.
Hope this clear
V.Ambarani
Best Regards
12/03/2008 8:39 AM
Ever see an oil filled transformer blow up? It is spectacular! But... you are going to get to see it up close and personal. Buy a new transformer.
12/04/2008 12:24 AM
Dear Friend
While you have a valid point, I take it for granted, since it is a basic protection feature for this size of transformer, that oil over temp. protection equipment is provided & therefore blowing up of transformer is a remote possibility. But if such a catastrophic situation does arise, then it is like a bomb explosion!!! Very very serious problem.
Thanks and regards
Anonymous Poster (2); ashoktoshniwal (2); SURYAKANT JATANIA (2); V.Ambarani. (1)
