We are currently trying to produce a part using a 2-part self skinning polyurethane foam. We are using a metering machine to mix the materials and inject into a mold. We are not getting consistent results. Parts are varying in weight, feel, stiffness, and the amount of air bubbles seen at the surface. We are injecting the part at the bottom of the mold and allowing the foam to rise towards the vent that is at the top of the mold. We are using heat to help kick the foam faster and shorten our cycle time. The metering machine is set up with a dynamic mix head so it is mixing the material at 3000 rpm before injecting into the mold. Our shot sizes vary between 9cc and 98cc (.38 ounces and 3.9 ounces).
Are we ever going to be able to repeat this process so that each part has the same feel, weight, density, and skin thickness? Are we asking to much from a metering machine to try and repeat itself thru this process?
