Previous in Forum: Aluminum cable current capacity   Next in Forum: MCCB Sizing Calculation
Torque Synchro Chain - Basic Principles
12/02/2008 10:11 AM
What is the basic principle of torque synchro chain? and if we are using a very old kit (20 years old) but its not previously used would it be efficient ? and one more thing if we are deploying this kit where there is a chance of ingress of grease (like movement of antenna where mechanical parts lubricated through grease) will it need to be water tight as well ? help and answer is appreciated
Re: TORQUE SYNCHRO CHAIN
12/02/2008 12:03 PM
hello Atif,
in general synchros transmit data from one place to another using transmitters and receivers.
torque synchro chains are basically deployed for fine movements or producing very small torques, as in your pointer movements in measuring devices etc.
so the basic principle here is of the rotary transformer. Current is fed to both the Transmitter and the Receiver from the same source .
the torque, as you know, is produced by the interaction of 2 fields - the stator field and the rotor field. and when the rotors are aligned the torque sums up to Zero.when the windings are in a perfect alignment maximum voltage will be induced in the secondary wndgs of the transformer, if the windngs are perpendicular to each other voltage will be zero otherwise the voltage will vary from zero to max.. so it forms a sine wave like pattern.
