I'm designing something where i need to be able to change out a piece which shall be connected to a cylinder (rod end with flat 4 hole mount) Via a quick disconnect device (the device in question). I need to be able to simply pull a pin remove the piece, slide on a new piece, lock into place, and continue running the machine. There will be minimal loads on the connection. and the removable piece will be a simple flat plate. My current thought process first went to a dovetail slide type of connection with indent pin. I have also looked into some linear slide bearing (carriage/rail type) which could be modified to work. I don't want to over-complicate things, and seem to be looking at the problem with tunnel vision. I've already started down my dovetail path, but just don't want to miss out on another set of mind's, alternative ideas. I don't want to overlook a very simple option, and am wondering if someone might be able to think of something outside of my box which could be taken into consideration.
Thank you.
