I forgot my password.
Don't have an account?
I'm looking for mild steel box section that is seamless and bright polished.
The idea is to reduce the amount of polishing required to a welded fabrication prior to plating process.
Typical sizes 20x20x1.5mm, 25x25x1.5mm and 30x30x1.5mm
Your best bet is to directly contact a steel supplier/mill. Depending on the quantities you require, they may be able to provide custom mill work at competitive pricing -- factoring in labor savings on your end.
Thank you . I might just do that.
