Previous in Forum: Differential Equation   Next in Forum: Standards or Manuals for Silo Building and Mechanical Conveyors Assembly
17 comments
Polarized Connector
12/03/2008 8:57 AM
I have been looking all over for a simple connector, that all of you have seen a thousand times
I had some sent to us for a solar panel project, and they worked great to interconnect the panels. But I just can not seem to find any that are like them. I can find all sorts of light duty ones. 16ga etc.
The ones I got and now need are like 2 feet or so in length,, and HEAVY wire. 14 Min 12 preferable.
Obviously they were made, because I have 4 sets of them in use now. But online all I can find is short length and light ga wire versions.
Actually any type of cheap polarized connector semi weather resistant will work.
suggestions?
Thanks
Good Answers: 266
Re: Polarized Connector
12/03/2008 10:05 AM
12/03/2008 12:42 PM
Yeah that the stuff,, But again only 16 ga wire.
Thanks tho.
12/03/2008 12:43 PM
I can't vouch for the source (and I'm looking for a better one) but here's a place that at least carries some 12 gauge ones:
http://www.solarseller.com/low_voltage_dc_pumps__lvm__teel__accessories__plugs_and_extensions.htm
Drone 601
(who's lost his password, apparently)
12/03/2008 1:57 PM
Now thats better, good Job!
I always forgot my password too so set it up in a cookie and let it auto log me in.
Good Answers: 68
12/04/2008 2:51 AM
Hello NSS, I found thes that look the same or very similar with male and female mic' jack type plug and socket.
Still looking have only just started. Don't panic!
Take care..........
MMJ-HCB Hyper Connector 3set
MMJ-HC Hyper Connector Set
New Hyper Connector Series are ideal for 7.2V battery pack. The Gold plated connector jacks are 4mm Euro Connectors and when inserted into the red molded housing, prevent from short circuit and reverse correction. Simply pass the wire through the red housing then solder it to the male/female connectors, then push the connectors to the housing until you hear a 'click' sound.
Source : MuchMore
12/08/2008 9:23 AM
Take heed!
These connectors can not be plugged or unplugged under power. Although they can not be reversed polarity wise, on a trial, they will make contact.
Wangito
Never trade luck for skill.
Good Answers: 68
12/08/2008 12:36 PM
Hello wangito:
So they are like any other loose wire connector and, NOT like a plug?
Because for the applications I have seen mentioned they will likely be joined.......for life?
But, you make a very good point.
Good Answers: 68
12/04/2008 3:05 AM
Hello again NSS,
guess what.......I found them.
Polarized Connector 2-Wire - Plug & Socket
Mfr. Sea-Dog $3.82
  • Injection molded PVC
http://www.go2marine.com/product.do?no=11884F
Good luck
hope you can get what you want near to where you live or can get them by post?
Good Answers: 94
12/04/2008 4:41 AM
How about the heavy battery connectors used on race cars & breakdown vehicles, they take up to 50A & 20mm² conductors.
12/04/2008 8:23 AM
These are often found in auto parts type stores. (Auto Zone /Advanced / NAPA). I don't know what they are specifically intended for, I think for lights on trailers. I used them on my racing Mustang for quick parts removal. (coil / MSD ignition box) You can find them in additional pole configurations also.
12/04/2008 2:05 PM
Yes thats everyone for helping But remember the wire has to be at LEAST 14 and that just barely good enough 12 is best. and there are very few at best of them.
Thanks for everyone, keep lookin'
Good Answers: 68
12/04/2008 10:12 PM
Hello NSS,
The wire gauge is:
Polarized Connector
Part# 11884 | Mfr. Sea-Dog | Mfr# 426880
  • 16ga wire
Cannot say the length, this type of connector comes in about 6 different sizes with different poles. I don't know if you want to order a pair, or thousand for a product you make. But either way I think a short request to the 'Sea-Dog' seller would find the answer?
Take care...........
Good Answers: 68
12/08/2008 12:40 PM
Hello NSS,
can I ask what you want them for?
Sorry but my nose was getting so long I had to ask!
Take care..............
12/08/2008 4:20 PM
Interconnections between solar panels, that are sometimes in series, and sometimes in parallel.
In sreies, 350 watts at 5 amps
Parralel could be at 15 amps. or even 20 but thats the main line, these are inter panel connections, 87 watts 5 to 6 amps.
Joe
Good Answers: 68
12/08/2008 4:41 PM
Hello NSS,
Thanks! Just wondered and being nosey!.
Good luck and let me know if you have any luck getting them please.
United States - Member - Les Etats Unis
12/04/2008 7:02 PM
Maybe they were custom made for a specific purpose. Often, I need to order the connectors and the cables separately and solder or crimp them myself. I generally can find anything I need from Allied, Newark, Mouser or Graybar. Sorry I do not have the time to look these up in more detail for you.
No trees or ecological systems were harmed in the creation or transmission of this message. However, a large number of electrons were horribly inconvenienced.
Good Answers: 68
12/06/2008 12:47 AM
Hello NSS,
I emailed the man you want Mr B Miller at:
bmiller@go2marine.com
945 Hildebrand Ln. NE, Suite 220
Bainbridge Island , WA 98110
Tel: 1-800-998-9508 or 206-780-5670
Fax: 1-800-998-9507
He may reply to your thread here, so keep looking...............
Take care................
Register to Reply 17 comments
Anonymous Poster (1); babybear (7); Electron Oasis (1); Nigh (1); NSS (4); ozzb (1); Phys (1); wangito (1)
