Previous in Forum: Blind to withstand Corrosion Allowance   Next in Forum: Chain Conveyor
Helical Compression Spring
12/04/2008 5:07 AM
i want to measure OD of helical compression spring. is there any standard method like inspection with Go No go ring gauge.
if yes please let me know
Kedarg6500
plan the work & work out your plan- Swami Vivekanand
Good Answers: 183
Re: spring inspection method
12/04/2008 7:03 AM
Yes if you look in the catalogue of the company Gutekunst (Germany) A spring manufacturer, you find at every spring description the diameter of a gauge for external and an other for internal limits. Tolerances are according DIN.
United States - Member - Woohoo Engineering Fields - Mechanical Engineering - New Member
Re: Helical Compression Spring
12/05/2008 10:41 PM
I'll begin by saying that I work for a spring manufacturer in the US who makes hot and cold wound springs.
It really depends on the customer and the tolerance required when determining how to inspect the part. For standard tolerance springs, we generally check the OD with calipers on the end coil. For certain applications we also check to make sure it fits in a tube or over a rod of a certain length and diameter. If you want to specify a ring gauge, it is acceptable, but you should either provide the gauge or be explicit in specifying the diameter and length of the gauge.
Also be aware that cold coiled springs are much more accurate in the OD than hot coiled spring. Hot coiled springs are usually made on a tapered mandrel to allow them to pull off and they see changes in their OD during heat treat.
I hope this information helps.
Self-motivational quote: "If they can make penicillin out of moldy bread, they can sure make something out of you." -- Muhammad Ali
Register to Reply 2 comments
