Previous in Forum: Helical Compression Spring   Next in Forum: Encasement
Chain Conveyor
12/04/2008 6:14 AM
Why chain Conveyor Flights is to be bend during runinig ? I am facing lot of problem bending of flights.If any one have an idea please mail me hospet123@gmail.com
Good Answers: 266
Re: Chain Conveyor
12/04/2008 7:15 AM
One chain longer than other, Improperly tensioned, bed not level
Good Answers: 101
Re: Chain Conveyor
12/04/2008 9:58 AM
Uneven loading may also cause this.
Re: Chain Conveyor
12/05/2008 2:55 AM
Check the alignment of the Drive sprocket, and the Flight thickness can be increased by 1.5 or Doubled
Re: Chain Conveyor
12/05/2008 10:32 PM
Two chains..." motor " side sprockets should be locked to the drive shaft...the opposite side should not be locked to the shaft and should be allowed to " freewheel "....basically...out of 4 sprockets , only the drive sprockets should be locked to the shaft..the other 2 will find their own center if allowed to...this compensates for minor differences in chain legnth , etc
Assuming that drive sprockets are keyed in the same location..
Anonymous Poster (2); DVader1000 (1); ozzb (1)
You might be interested in: Conveyor Chain, Leaf Chain
