Problem:
I have a mixed liquor conduit that carries flow to a
splitter box, where it flows up and overflow into three identical weirs, which
then go to three identical clarifier (200 ft diameter). The mixed liquor flow is by gravity and the
flow is not turbulent (fairly steady). The
flow to each of the weir is not even.
Clarifier number 2 get more flow than #1 and #3 (See Attached PDF for
pictures). Without resorting to
expensive CFD model, hydraulic lab, or even purchasing multiple expensive
magnetic meters, what weir formula best describe the flow (Q) given that for
the three weirs, flow to #2 is more than #1 & #3 so that I can use in our
computer PLC/HMI programming?
I believe that clarifier #1 get mores flow because of momentum. Also because water likes to continue on a straight
path rather than turn a 90 degree bend (as in the case for flow to clarifier #1
& #3).
I am aware of the Francis formula: Q=3.33(L-0.2H)*H^1.5
However, the Francis formula will give me a wrong flow value
for the splitter box case. So if you
know another formula or research paper, please let me know.
