Does any one know of a glove, or material that can be used on gloves for handling butyl adhesive sheets in a work environment? So far, the only things we have found are; soaked polyester work gloves(unacceptable for the the worker and the work space) and nitrile gloves sprayed with PTFE(only good for about 3 "contacts" before reapplication is required). Thank you for any advice and suggestions!
