Does anyone on CR4 use Turbocad? (specifically turbocad 6). I have a strange problem which I cannot see the answer to.
I have recently changed computers and OS from XP to Vista. I have moved all my old project drawings to the new machine, and have no problems with most. However one drawing that I am currently working on exhibits a very strange phenomenon. An example would be after a drag 'n drop operation the cursor drops to the bottom left corner of my screen.
While this is strange, what I find stranger is that other drawings behave normally, even when opened in the same session, that is both drawings on screen at the same time. Now if I copy the "bad" drawing and paste it into the Good drawing then that too exhibits the same fault. Select the "Bad" drawing and cut it out and the remainder reverts to normal operation. If I send the drawing back to my old machine then it too reverts to normal behaviour.
Help please as I am mad, but this is exacerbating the symptoms.
Regards
Chas
