Previous in Forum: Conductivity   Next in Forum: Vacuum Pressure
ASME VIII Div.2 ED.2007
12/11/2008 3:44 AM
Dear guys,
Today i've been pre-audited to get licence for U2-stamp & real audit will be 2 weeks ahead. They had warn me to do manual calc. for all div.2. I'd ready for shell, ellips & hemi- head.. But stuck on opening reinf. calc.
Anybody has gone throught b4? Can share info on how to handle these auditor?
Re: ASME VIII Div.2 ED.2007
12/11/2008 10:30 AM
The opening reinforcement calculation is spelled out pretty well and straightforward in ASME VIII Div 2 - Part 4.5.4 along with figure 4.5.1 and the nomenclature in 4.5.18.
The only advice I have is to make sure you are organized, neat, and thorough.
04/14/2012 5:32 AM
you can go to www.standardshop.org
there sale a lot of asme aws api standard and so one .can immediately download,and very cheap low price!
Hobbies - DIY Welding - pipewelder
12/12/2008 10:00 AM
I have went through this many times and my advise is to spend the time to have your calculations very well laid out in an easy to understand format and checked to be correct before the auditors look at them. I used to do my on calculations in house but nowadays I find it much easier to have a 3rd party engineering co. do them and have their PE stamp and sign them before I review and check. It seems when I hire a 3rd. party co. to do them I always get them back very well done and in a format that is easy for the A.I. and myself as well to go over and check.
pipewelder
12/13/2008 12:11 PM
I think it is easier -especially at that tight and critical time- to proceed a computerized calculations by using a suitable software like PVElite, and this needs to modify the quality control manual to settle that statement. In addition to that, you have to prove that you had carried out such a verification for the soundness of that software. Otherwise, I recommend the suggest of our friend pipewelder to hire a PE to do that.
Note. I used to proceed a manual calculations for 1st audit and renewal of ASME VIII Div.1 Stamp U, since 1990. Because at that time I found a lot of mistakes at ready made softwares, in addition the ready made calculations was insufficient to cover all ASME requirements at that time.
Register to Reply 4 comments
Abdel Halim Galala (1); Guest. (1); jackchen (1); pipewelder (1)
