Transmission Problems - Toyota Run X Triptronic 1.8
12/11/2008 10:22 AM
Hello
I have a toyota run x 1.8 auto triptronic.vehicle does not chnage to 4th gear and triptronic does not function.a computer was plugged in by a toyota dealer,gave code
Re: Transmission Problems - Toyota Run X Triptronic 1.8
12/22/2008 7:22 AM
The rev sensor could be in the transmission , or the engine. I am not familiar enough with your model to tell you for sure. Contact a local parts distributer for a picture of the replacement sensor. That should give you something to look for on your car. If that does not help, try googeling Toyota rev sensor, and finding some Toyota speciality sites. Good luck.
12/22/2008 10:49 AM
hello BoB
I do not know where the sensor is.the vehicle was at a dealer.the vehcile is an import from japan.i had a look at all the wires from bumper to bumper and no luck.
