hi,
i designed the hemisherical dished end as per IBR code and find out the minimum thickness.now i want to find out the blank size required for manufacturing of dished end.is there any formula to find accurate blank size.
Try searching for pressure vessel dished end suppliers. I haven't looked recently, but have found supplier information in the past in table format in which the specific details of formed heads are listed.
These are normally listed by diameter and plate gauge and the ones that I have located in the past show the blank diameter for each specific head configuration as well as such things as volume. You can probably find one that closely approximates your finished head radius and plate thickness to determine your needs. A hemi-head is the same whether to IBR, ASME, or any other standard.
