when i start or reboot my pc (windows xp) , one dialogue box always appears namely "WINDOWS HOST SCRIPT SETTINGS". what is this? what should i do to settle this? please help me..thanks.
Hope this helps.. It gives a short history of why the program is there in the first place.
Guud luck.
To disable Window Scripting Host (WSH).
The majority of viruses recently have been email-based. They are often written in VBScript which is a scripting language used to automate tasks without user intervention (or perhaps, one even knowing the script is running). Microsoft built the Windows Scripting Host (WSH) as an application to run vbscript programs. It ships as an integral part of Windows 2000 and Windows XP. WSH is also included when one downloads Internet Explorer 5. WSH can be used to get access to the Windows commandshell, file system, and registry. Lots of people know vbscript. Its complexity is low, at least, the complexity to write virus code.
To find out if the Windows Scripting Host is enabled on your PC:
Click Start | Run | cmd
Type wscript in the command shell
If its enabled, the Windows Script Host Settings dialog box will poppup.
You can protect yourself from these malicious programs if you have up-to-date antivirus code resident. This is becoming an absolute requirement in corporate environments. If you don't have that level of protection, you might want to block the vbscripting threat by disabling the Windows Scripting Host which is the agent that executes the .vbs files. There are several methods which are compatible for Windows NT / Windows 2000 and Windows XP:
Rename or delete the WSH executable : wscript.exe
Its normally found in the system32 folder.
Block WSH from executing .vbs files by removing the file association
Right-click My Computer
Select Open from the menu
Select the View tab
Select Options
Open the File Types tab
Select VBScript Script File from the list of file types
If its not there, then WSH is not installed or has been disabled. If its there
Click on the Remove button to remove the ability of WSH to run .vbs scripts.
Another alternative if you want to know when a script has been activated, you can use the Edit button to change the default action for .vbs files from Open (running) them to Edit . That is open script in Notepad.
Tace care and happy holiday.......................
you are almost as nutty as me! Whats with the waving, or have I missed something?
Take care and have a wonderful holiday!................
Oh, right............Same to you my friend! You and a short list of others have help me through some pretty low times this year wire. Thank you! And a very merry Xmas to you. Have a great one!
